![]() | Home > Maintenance & Modifications > Stainless bolts for roll cage |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3485 ![]() ![]() ![]() |
Galvanized bolts in the vicinity of stainless will tent to sacrifice the zinc coating of the bolts faster, although the washer size (surface area) is not that large, so the effect may not be visible that soon. Just fyi.
There are zinc plated bolts, which tend to rust in no time, and then there are hot dipped galvanized bolts, which have a decent zinc coating. Example (local site): https://eshop.wuerth.com.mt/din-933-steel-88-hot-dip-galvanised 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 ![]() ![]() |
If you can cope with the Defender being off the road for a few days, you can remove, blast and then get your existing bolts Re-coated. Zylan coating seems to be the most resistant coating currently available, but not many places do it.
Anyway, if you get them re-coated, then just spray som Dynax UC on them https://bilthamber.com/product/dynax-uc/ This will keep them in good condition for about 12 months, before you need to re-spray with UC again. π[/url] |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 ![]() ![]() ![]() |
Why not talk with SD, post them a few photographs, I found them very helpful sorting out a Roof Rack issue a ew years ago. NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 823 ![]() ![]() |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2290 ![]() ![]() ![]() |
You can get a big bag of them from screwfix π Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 947 ![]() ![]() |
I have been in touch with SD and they are sending me some new external fasteners
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Good result - clearly their good reputation is deserved π
