![]() | Home > General & Technical (L663) > DRL's |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 829 ![]() ![]() ![]() |
I thought the whole point of the DRL’s is that they are on all the time and could not be turned off?
Not sure why you would want to turn them off? Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 ![]() ![]() |
DRLs can’t be switched off. 24MY 90 D250 HSE, Tasman Blue
Mark V2 Member Since: 13 Mar 2023 Location: Peterborough Posts: 59 ![]() ![]() |
How did you do that? Now sold: 2023 Defender 90 D250 X-Dynamic SE (Eiger Grey). |
According to the OP they can? Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Theatrically you are not supposed to be able to turn off DRL's on UK spec cars. On VW's you can use VCDS to add an additional item to the lighting set-up menu which allows them to be switched off so maybe something similar here? Now sold: 2023 Defender 90 D250 X-Dynamic SE (Eiger Grey).
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2921 ![]() ![]() |
lf l turn the light switch past the side light position to "off" the DRL's go off.
Then they come back on, but if you do it again they stay off for that journey. Sometimes, the switch won't turn them off unless you are stationary. lt's almost like you are fighting against the computer which says "you can't turn these off" Normally l leave them on, l would just like the option to turn them off. |
They are off when in park, but once in gear they come on. On my 3 Defenders and all previous LRs with them there’s never been an option to switch them off, unless configured through the vehicle software then they’re off completely.
Side lights and the DRLs use the same part of the headlights only ones brighter than the other, sounds like the side lights are being switched off, I think briefly there’s no light on, then the DRLs will come on. I could be way off the mark though! 24MY 90 D250 HSE, Tasman Blue |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 ![]() ![]() |
Why would you want them off?
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 270 ![]() ![]() |
It’s illegal in the UK to turn them off whilst the vehicle is moving 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
l honestly didn't know that.
They will stay on at all times from today. |
all new cars sold after February 2011, where fitted with DRL,s and it is illegal for these cars not to have them on when in motion. cars before that are exempt. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
