![]() | Home > Off Topic > 3 phase mains question |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1125 ![]() ![]() ![]() |
I recall i learned that in Europa the single phase voltage of 230v is between line and neutral. Between lines it's 400v
How does the UPS display the load? In Amps? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3690 ![]() ![]() ![]() |
What info have you got at the UPS, Amps? You’ve got 230V per phase, so multiply that by the load in Amps of that phase and that will give you wattage per phase. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
Yea I have info in amps on the UPS which I can work out to Watts but an on line calculator also mentioned power factors and option to choose AC single or AC 3 phase and then options for L2L or L2N
The amount of Watts consumed varies depending on single or L2L etc. I worked through all options and took each result so I have a range of Watts to choose from We have the sparks due in next week to clamp test each output so we can get a reading to better understand the server racks that are consuming the most so we can try to re-balance the outputs. L1 - 75% L2 - 62% L3 - 3% We know L3 is under used at the mo so we need to work out which kit to move etc 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
