![]() | Home > Puma (Tdci) > Smoking on cold start-up. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
At least you now know what you've bought!
It appears to be entirely normal for the TDCi engine to smoke for a few seconds after start up, mine has done it for the last 260k miles, it is is worse in the cold weather (it can be quite embarrassing) so I think it is to do with the pre-heat and starting routine. It is a question that has cropped up several times before on the forum. |
Hideousfish Member Since: 24 May 2023 Location: Preston Posts: 7 ![]() ![]() ![]() |
Thanks for your help, really appreciate it. Yeah I think this seems to be the case and very common, just wanted to double-check there wasn't anything else sinister it might be. To be honest, I think it's all pretty much a new engine now lol. But hey. I still love the weird and wonderful beast
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 972 ![]() ![]() |
I had the same symptoms, albeit with a 170k engine, New glow plugs sorted it for me.
Mine would run fine but with a good amount of white smoke which cleared once things warmed up a little. All gone now. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Mine does it too. Could it be diesel that has leaked past the injector tips after turning the engine off after the last use?
The fuel rail will have a considerably pressure stored in it and the injectors needle seal will no doubt let some fuel by > 110 XS Double Cab |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
Same here with my 2.4 2007. Mine is decat and egr off as well, so smells pretty bad when cold. Puma 110" SW
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
If it’s white smoke it’s unburnt fuel and quite common on cold start up. A high concentration diesel fuel system cleaner/flush may help. Also, get your glow plugs checked
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Thanks for all the suggestions, much appreciated, will see how things go
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
As said above, it could be glow plugs and there are threads on that to read through. Could also be injector seals that need replacing, my one got all smokey on start-up when the injector seals were failing. If the engine isn't leaking oil all over the place, then it'll be glow plugs or the various systems that go with glow plugs like the relay or big blue fuse thingy that lives under the driver's seat. The other 'bad starting in cold weather' threads will explain more.
