Home > General & Technical (L663) > New to here. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1409 |
Ah. I thought it was the ionisation thingy you were talking about. I have the climate thing on my app. Works a treat but thought it came standard. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
22nd May 2023 7:08pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2661 |
Definitely get the proper fixed towbar, the detachable one is rubbish.
22nd May 2023 8:24pm |
mf7480 Member Since: 14 Jun 2021 Location: Gloucestershire Posts: 93 |
Why do you say that? I was apprehensive about the detachable as we do a lot of very heavy towing and the fixed wasn’t available when we ordered, but we’ve had no hassle at all. It’s still got zero play in it after 2 years work.
22nd May 2023 9:36pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1419 |
If your IIDTool is a BT (Gen 3) you will just need to do a change of vehicle with GAP Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
22nd May 2023 9:45pm |
Because the receiver rusts within a year or so, meaning the tow ball section won’t locate properly without a hammer. The replacement (under warranty) did the same in one winter, so I bought a fixed one instead. |
23rd May 2023 4:44am |
Fair enough, not a problem I’d come across but I covered the receiver and socket in grease the first time I used it, and never took it off again.
23rd May 2023 7:02am |
Chris S Member Since: 22 May 2023 Location: Aberdeenshire Posts: 43 |
I have a Gen 2, I believe I can do a trade in for a Gen 3 along with some ££ |
23rd May 2023 9:13am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2878 |
An occasional spray with WD-40 or similar prevents this happening |
23rd May 2023 11:28am |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 141 |
Yes, just contact us. We will do a partial exchange. https://www.gap-diagnostic.com/shop/exchange/ Brakes on the D300 can be modified to fit 18's (smaller rear calipers). But unless you are towing a heavy un-braked trailer or towing through mountains regularly, I can't imagine that the D250's brakes won't suffice. RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
23rd May 2023 3:41pm |
Thanks for all the advice/ information, I have revisited my build and gone for a D250 with more toys and it still came out cheaper than the D300 I originally was looking at.
23rd May 2023 4:57pm |
Sadly not, tried that as well as grease etc. but both the original and replacement are rusted. Too much road salt. |
24th May 2023 9:16am |
What towbar would you recommend, I would prefer a multi height? |
24th May 2023 4:50pm |
The genuine one is probably the best option:
https://accessories.landrover.com/gb/en/la...-pre-23my/ I’ve got an aftermarket one which looks pretty good and is much cheaper, but obviously I’ll need to install it myself. Because I have an existing genuine towbar I can reuse the electrics from it and avoid the hassle of integrating an aftermarket harness into the vehicle systems, which is the main issue with non-LR towbars. |
24th May 2023 6:01pm |
Which part rusts exactly? l will keep an eye on it. |
24th May 2023 8:30pm |
