![]() | Home > Wheels & Tyres > D90 pulling hard right when brakes applied |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3516 ![]() ![]() ![]() |
Probably the problem was already there, but now accentuated by the wheel offsets.
I would look at the calipers / discs first. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Almost certainly a sticking LH calliper, I'd say. Darren
I agree with this. The spacers, wheels and tyres mean there is more leverage on the swivels and steering mechanism. As in it is easier for the tyres to turn the steering wheel. But........ I would get under there and make sure that the wheel bearings, swivel pins/bearings, bushes on the radius arms, the track rod ends and steering drop arm ball joints are all good. Any one of these can create a pull to one side. The other thing is if you have a spring lift then the steering castor will be out and that can also exacerbate the effect of worn steering and suspension components. |
