Home > Puma (Tdci) > Heater Fan 2.4 |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
The third position probably burned out.
This happened to me and the third position was burned out. Luckily, my electrician was able to resurrect it and it's still working until now. If he wasn't able to make it work, you need a new assembly. I asked a friend of mine who has a Landy shop, he suggested wiring relays to each switch position to take the load. I told him to install them on mine, now I can use all three positions confidently. If one of them stops working, all I have to do is replace the corresponding relay. I hope this helps you. |
18th May 2023 3:04am |
