Home > Puma (Tdci) > Heater Fan 2.4
The Monkey
Ireland
Heater Fan 2.4
Evening all, my heater fan works on positions 1,2 but nothing on setting 3. Any ideas as to what might be the cause of it.
Thanks.
Post #993055 17th May 2023 9:34pm
HardCharger
The third position probably burned out.
This happened to me and the third position was burned out. Luckily, my electrician was able to resurrect it and it's still working until now. If he wasn't able to make it work, you need a new assembly.
I asked a friend of mine who has a Landy shop, he suggested wiring relays to each switch position to take the load. I told him to install them on mine, now I can use all three positions confidently. If one of them stops working, all I have to do is replace the corresponding relay.
I hope this helps you.
Post #993070 18th May 2023 3:04am
