Home > Technical > Which winch controller and socket?
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Has anyone got any recommendations for either a decent wireless controller or wired socket and controller which would be compatible with this solenoid?
Thanks.
Post #992706 15th May 2023 11:53am
If you haven't already done so, you might want to take a look at this thread.
Post #992710 15th May 2023 12:21pm
rallysteve
vote for the Lodar mini from me 02' 110 TD5 Double Cab Rebuild Thread
Post #992717 15th May 2023 1:18pm
TamarBlue11
Thanks guys, have enquired about lodar will have to see what costs are. Any idea how to work out which each of the spade connectors on my solenoid are for to wire the controller correctly? They don't seem to be labeled.
Post #992724 15th May 2023 2:37pm
The middle spade will no doubt be the "common", then the LH and RH will operate in & out respectively.
You can either connect the middle to chassis ground, and introduce 12v to either of the others, or middle spade has 12v and the outer 2 spades switch to ground when you operate the remote.
you'd have to check the destructions that come with the remote kit to see how their switched output is setup though.
Post #992930 17th May 2023 7:40am
TamarBlue11
Thanks Jim.
Post #993076 18th May 2023 5:56am
rallysteve
Worth noting that if you do want a controller such as the Lodar mini then it is worth looking at the Warrior Winches Centurion controller which is a re-badged version of the Lodar for a fair chunk less money.
Post #993089 18th May 2023 7:36am
