Home > Technical > Which winch controller and socket? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
If you haven't already done so, you might want to take a look at this thread.
15th May 2023 12:21pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
vote for the Lodar mini from me 02' 110 TD5 Double Cab Rebuild Thread
15th May 2023 1:18pm |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 |
Thanks guys, have enquired about lodar will have to see what costs are. Any idea how to work out which each of the spade connectors on my solenoid are for to wire the controller correctly? They don't seem to be labeled.
15th May 2023 2:37pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
The middle spade will no doubt be the "common", then the LH and RH will operate in & out respectively.
You can either connect the middle to chassis ground, and introduce 12v to either of the others, or middle spade has 12v and the outer 2 spades switch to ground when you operate the remote. you'd have to check the destructions that come with the remote kit to see how their switched output is setup though. |
17th May 2023 7:40am |
Thanks Jim.
18th May 2023 5:56am |
Worth noting that if you do want a controller such as the Lodar mini then it is worth looking at the Warrior Winches Centurion controller which is a re-badged version of the Lodar for a fair chunk less money.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th May 2023 7:36am |
