![]() | Home > General & Technical (L663) > Defender AWD -How does it work? |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 ![]() ![]() |
To my knowledge the P300 / P400 / P525 have full time 4 wheel drive , so 50/50 always.
I can confirm this with my P300. ( Quattro behavior, there is a reason Bowler uses this version for Rallye Championship) The centerdiff locks them if requested. Just buy a Petrol... ![]() ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 ![]() ![]() ![]() |
Does the new Def not use some variant of a Haldex unit? I didn't think it had a centre diff as such.
Since as a vehicle it doesn't really interest me one iota I could well be wrong. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 ![]() ![]() |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 161 ![]() ![]() |
Not Haldex.
Twin speed transfer case attached behind the auto box, has full time permanent all wheel drive unit with a centre diff & 50/50 torque distribution to the front and rear driveshafts, selectable high and low range. The transfer case is identical for all engine derivatives. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Thanks for posting that diagram Retroanaconda - it’s a difficult thing to explain otherwise. I was also told that the system can re-engage the front drive in 1/300th second or as soon as any wheel slip is detected. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2921 ![]() ![]() |
Why do you want to know how the AWD works.
lt's a very good system and l've never got stuck despite only having the basic coil spring specification with no locking diffs or configurable terrain response etc |
Thanks for the diagram, so it is a Haldex-type set-up.
Another reason not to buy one, as far as I am concerned. |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1440 ![]() ![]() ![]() |
Some people think it's important to understand what they're buying. https://www.defender2.net/forum/topic87123.html
DavidLew Member Since: 11 May 2023 Location: Hunter Valley Posts: 3 ![]() ![]() |
Agreed. There are lots of reasons but in my case I am specifically looking at the impact on towing and comparing any differences between diesel and petrol in terms of how AWD works. Paraphrasing Kant , Theory without experience is intellectual play but Experience without theory is blind |
Thanks.I have come across this diagram before but some confusing aspects for me. What is a D6H engine - Diesel 6cyl hybrid?? If its diesel of any sort then the technology only applies to diesel, at least in 2021? Defender? There are some odd comments likefully closed clutch with 50:50 torque split "as with a locked differential". The conventional locked differential can split torque anywhere from 0 to 100%. Open differentials always split 50:50 The diagram suggests a maximum of 50% torque to front wheels (never 100%) and front whheels can also additionally be disconnected from any torque. Suggests a bias to RWD Some have suggested a Haldex system and elsewhere a BorgWarner system which was used by JLR somewhere in past others have sggested " P300 / P400 / P525 have full time 4 wheel drive , so 50/50 always. " and others "Twin speed transfer case attached behind the auto box, has full time permanent all wheel drive unit with a centre diff & 50/50 torque distribution to the front and rear driveshafts, selectable high and low range. The transfer case is identical for all engine derivatives." ![]() ![]() ![]() Pity JLR doesn't release more info (that I can find) |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 507 ![]() |
Not a fan then!? ![]() I get it. But the world is getting cleaner and more efficient. These types of electronics are required now or the vehicle won't get built, and worse is yet to come - Pretty soon they're going to be expanding these ULEZ concepts further and further. You're going to need to get with the program eventually.. |
Not necessarily, old age may overtake the programme if I'm lucky!
Yes you are right, point taken! |
What are you doing on the L663 part of the forum if you don't like the vehicle!! l had a Porsche 928 I don't like Porsche SUV's Which is why l never lurked on that part of the Porsche forum. |
