Home > General & Technical (L663) > Defender AWD -How does it work?
DavidLew
Australia
Hi all
looking at buying 2023 Defender 110 6 cyl.
I am seeking a technical paper or review on the new defender AWD system.
From what I can gather its a clutch based torque vectoring system but I want to find out how it operates such as torque split characteristics, if it prioritizes 2wd RWD and when, if it can be modified in settings or by configurable drive mode etc, how it works in conjunction with "active rear dif with torque vectoring by braking" etc
Importantly, I have heard conflicting advice as to whether only the diesel received "intelligent AWD" that biased preference for 2WD (RWD) (reducing emissions)
As I am looking at Towing, I am keen on diesel D300 but would prefer a more permanent full time AWD system, if say this is a feature of the petrol version,even if it only selects say 20% torque"as needed" to front wheels (as opposed to 0%).
Thanks
David
Post #992187 11th May 2023 9:04am
Defendit..
Netherlands
To my knowledge the P300 / P400 / P525 have full time 4 wheel drive , so 50/50 always.
I can confirm this with my P300. ( Quattro behavior, there is a reason Bowler uses this version for Rallye Championship)
The centerdiff locks them if requested.
Just buy a Petrol... Very Happy No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #992197 11th May 2023 10:32am
Does the new Def not use some variant of a Haldex unit? I didn't think it had a centre diff as such.
Since as a vehicle it doesn't really interest me one iota I could well be wrong.
Post #992225 11th May 2023 2:52pm
Retroanaconda
Post #992227 11th May 2023 3:04pm
WizzardPrang
Not Haldex.
Twin speed transfer case attached behind the auto box, has full time permanent all wheel drive unit with a centre diff & 50/50 torque distribution to the front and rear driveshafts, selectable high and low range. The transfer case is identical for all engine derivatives. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #992231 11th May 2023 3:08pm
Tim in Scotland
Thanks for posting that diagram Retroanaconda - it’s a difficult thing to explain otherwise. I was also told that the system can re-engage the front drive in 1/300th second or as soon as any wheel slip is detected. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #992232 11th May 2023 3:12pm
lightning
Why do you want to know how the AWD works.
lt's a very good system and l've never got stuck despite only having the basic coil spring specification with no locking diffs or configurable terrain response etc
Post #992280 11th May 2023 5:59pm
Thanks for the diagram, so it is a Haldex-type set-up.
Another reason not to buy one, as far as I am concerned.
Post #992288 11th May 2023 6:55pm
DSC-off
Some people think it's important to understand what they're buying.
https://www.defender2.net/forum/topic87123.html
lightning wrote:
Today l reversed on to a muddy field to turn around, only the rear wheels were on the field, the front wheels were on solid ground.
When l came to drive away the Defender didn't want to move, the rear wheels spun and it barely moved forward.
l thought that drive would be shifted to the front wheels.
Post #992306 11th May 2023 8:44pm
DavidLew
Australia
Agreed. There are lots of reasons but in my case I am specifically looking at the impact on towing and comparing any differences between diesel and petrol in terms of how AWD works.
Paraphrasing Kant , Theory without experience is intellectual play but Experience without theory is blind
Post #992315 11th May 2023 10:25pm
DavidLew
Australia
Retroanaconda wrote:
Thanks.I have come across this diagram before but some confusing aspects for me.
What is a D6H engine - Diesel 6cyl hybrid?? If its diesel of any sort then the technology only applies to diesel, at least in 2021? Defender?
There are some odd comments likefully closed clutch with 50:50 torque split "as with a locked differential". The conventional locked differential can split torque anywhere from 0 to 100%. Open differentials always split 50:50
The diagram suggests a maximum of 50% torque to front wheels (never 100%) and front whheels can also additionally be disconnected from any torque. Suggests a bias to RWD
Some have suggested a Haldex system and elsewhere a BorgWarner system which was used by JLR somewhere in past
others have sggested " P300 / P400 / P525 have full time 4 wheel drive , so 50/50 always. " and others "Twin speed transfer case attached behind the auto box, has full time permanent all wheel drive unit with a centre diff & 50/50 torque distribution to the front and rear driveshafts, selectable high and low range. The transfer case is identical for all engine derivatives."
Question Confused Shocked
Pity JLR doesn't release more info (that I can find)
Post #992318 11th May 2023 10:41pm
XplusYplusZ
blackwolf wrote:
"Since as a vehicle it doesn't really interest me one iota I could well be wrong"
"Another reason not to buy one, as far as I am concerned."
Not a fan then!? Laughing
I get it. But the world is getting cleaner and more efficient. These types of electronics are required now or the vehicle won't get built, and worse is yet to come - Pretty soon they're going to be expanding these ULEZ concepts further and further. You're going to need to get with the program eventually..
Post #992403 12th May 2023 3:41pm
Not necessarily, old age may overtake the programme if I'm lucky! Very Happy
Post #992406 12th May 2023 4:23pm
lightning
Yes you are right, point taken!
Post #992453 13th May 2023 8:55am
lightning
What are you doing on the L663 part of the forum if you don't like the vehicle!!
l had a Porsche 928
I don't like Porsche SUV's
Which is why l never lurked on that part of the Porsche forum.
Post #992454 13th May 2023 9:00am
