Home > Modifications & Maintenance (L663) > Retrofit / Upgrade Domestic Plug Socket
Defendit..
Netherlands
Next mod, the Domestic Plug socket - inverter is only capable till 180w. Not very useful except charging some devices.
So out with the old one and upgrade to an 12v 1500w Pure Sinus Wave inverter.
Location in my case under the loadspace in my Hardtop / Commercial.
Next power supply, this inverter can take up to 100 amps.
So I had to make made new 50mm2 / 0 awg Power cables of 4.5 ft. direct on the Battery after the BMS.
First testing with the remote on/off - monitoring display
Testing the Nespresso Essenza Mini coffeemaker ( 1100w) on the Mudstuff table
Finish with a new Domestic Plug Socket ( Schuko in Europe) , the look will be almost like stock.
Side panel back and connected. Recovery gear back in place.
Flat flooring back in.
Rubber lining and ARB fridge straps back in.
So a lot better prepared now for overlanding, or just lunch with coffee Very Happy
( Total costs of this project £ 275,- ) No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #989446 19th Apr 2023 8:33am
lightning
That's some fine work you've done there, and all invisible.
Great use of the under floor storage area for the inverter.
Post #989645 20th Apr 2023 1:27pm
Moo
Ukraine
That’s a nice set up. Also neat idea for the compressor. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #989653 20th Apr 2023 2:10pm
Defendit..
Netherlands
Thx @lightning & @Moo
Thread about the compressor and airtank can be found here:
https://www.defender2.net/forum/topic80080.html No Mud flaps for my 90.!
Post #989672 20th Apr 2023 4:29pm
camelman
Have you done anything to your battery / charging set up or will you only run the invertor with the engine running?
Post #989675 20th Apr 2023 5:10pm
Defendit..
Netherlands
For now I'am running the Inverter only shortly for coffee or my electrical inflatable matrass.
I have to find out in the morning if there is some juice left after a night of running the ARB fridge.
So maybe the Inverter needs a short startup and idle for powering the Nespresso coffeemaker
Planning is second battery in the future but that is expensive with all the charging and control devices needed. No Mud flaps for my 90.!
Post #989736 21st Apr 2023 8:30am
camelman
I suspect running the fridge all night of your main battery will definitely flatten your battery.
Post #989757 21st Apr 2023 10:22am
