Home > Modifications & Maintenance (L663) > Retrofit / Upgrade Domestic Plug Socket |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2870 |
That's some fine work you've done there, and all invisible.
Great use of the under floor storage area for the inverter. |
20th Apr 2023 12:27pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1407 |
That’s a nice set up. Also neat idea for the compressor. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
20th Apr 2023 1:10pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 431 |
Thx @lightning & @Moo
Thread about the compressor and airtank can be found here: https://www.defender2.net/forum/topic80080.html No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
20th Apr 2023 3:29pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3376 |
Have you done anything to your battery / charging set up or will you only run the invertor with the engine running?
20th Apr 2023 4:10pm |
For now I'am running the Inverter only shortly for coffee or my electrical inflatable matrass.
I have to find out in the morning if there is some juice left after a night of running the ARB fridge. So maybe the Inverter needs a short startup and idle for powering the Nespresso coffeemaker Planning is second battery in the future but that is expensive with all the charging and control devices needed. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
21st Apr 2023 7:30am |
I suspect running the fridge all night of your main battery will definitely flatten your battery.
21st Apr 2023 9:22am |
