![]() | Home > Modifications & Maintenance (L663) > Lower Side Trim Clips |
RickyBobby Member Since: 27 Jan 2023 Location: UK Posts: 15 ![]() ![]() |
A few pics nabbed from the PowerfulUK video.
![]() Click image to enlarge ![]() Click image to enlarge |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1438 ![]() ![]() ![]() |
Looking at the parts diagram they may be T2R31859 if they are the ones listed as HC2
![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks, that could be them!
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 439 ![]() ![]() |
No they are not, those are the same as the side cladding clips.
LR112137 Between 0,10 & 0,13 cents/pence a pc. The part number for the bigger clip is not exposed on the above view. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Well I had a good look today - all the clips are intact and secure but for some reason the panel sits about 1cm further out that the door at the bottom edge.
