Home > Modifications & Maintenance (L663) > Lower Side Trim Clips
RickyBobby
Anyone know the part number for the bottom clips of the lower side trim just behind the front wheel? The part that the mudflaps are attached to.
Pic attached, it is the purple clips - tow are used at the bottom. The top ones are mentioned in the doc and are not the same as the bottom ones marked in purple.
Post #988776 12th Apr 2023 7:22pm
RickyBobby
A few pics nabbed from the PowerfulUK video.
Post #988794 12th Apr 2023 8:22pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Looking at the parts diagram they may be T2R31859 if they are the ones listed as HC2
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #988804 12th Apr 2023 11:22pm
RickyBobby
Thanks, that could be them!
Post #988806 13th Apr 2023 5:39am
Defendit..
Netherlands
No they are not, those are the same as the side cladding clips.
LR112137 Between 0,10 & 0,13 cents/pence a pc.
The part number for the bigger clip is not exposed on the above view. No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #988810 13th Apr 2023 7:03am
RickyBobby
Well I had a good look today - all the clips are intact and secure but for some reason the panel sits about 1cm further out that the door at the bottom edge.
Post #988880 13th Apr 2023 8:13pm
