![]() | Home > Tdi > Defender 300tdi vacuum pump question. |
Dave12345 Member Since: 04 Jun 2022 Location: North West Posts: 87 ![]() ![]() ![]() |
Unfortunately I was unable to find the o-ring when I looked a few weeks ago. I’d try to very carefully clean up the original oring and refit with a dab of hylomar (beware - seriously carcinogenic, use gloves). M5 x 20mm bolts are suitable from a thread I have bookmarked.
It’s not possible to use generic o-rings from a kit as you’re probably aware, it’s Mickey Mouse shaped. My problem was the welch plug popping so all of the above was just researched as a possible preventative measure, someone more experienced may be able to offer more guidance. Ended up with a new pump personally. |
