Home > Tdi > Defender 300tdi vacuum pump question.
Davidarnol
United Kingdom 1995 Defender 90 300 Tdi HT Epsom Green
Hunting for an oil leak today and noticed that the outer (riveted) end of the vacuum pump was wet with oil, I read a post somewhere that mentioned a replacement o ring kit including small bolts (to replace the rivets) was now available. I have searched everywhere but can’t find any reference to it. Does anyone know if this is available in the Uk?
Post #988631 11th Apr 2023 5:43pm
Dave12345
United Kingdom 1989 Defender 90 300 Tdi PU Keswick Green
Unfortunately I was unable to find the o-ring when I looked a few weeks ago. I’d try to very carefully clean up the original oring and refit with a dab of hylomar (beware - seriously carcinogenic, use gloves). M5 x 20mm bolts are suitable from a thread I have bookmarked.
It’s not possible to use generic o-rings from a kit as you’re probably aware, it’s Mickey Mouse shaped.
My problem was the welch plug popping so all of the above was just researched as a possible preventative measure, someone more experienced may be able to offer more guidance. Ended up with a new pump personally.
Post #1005366 24th Aug 2023 10:38pm
