![]() | Home > Technical > Drive flanges Paddock PM770 vs Ashcroft 859? |
hjellemorten Member Since: 03 Oct 2022 Location: Bergen Posts: 28 ![]() ![]() ![]() |
Anyone know the difference between the drive flanges PM770 by Paddock and the 859 by Ashcroft
![]() PM770 https://www.paddockspares.com/pm770-heavy-...html?qty=5 859 https://ashcroft-transmissions.co.uk/product/859/ |
Thanks, just noted that neither one of these seems to work with my original Boost ally wheels.
![]() “These are to be used with Steel wheels or ZU alloys only.” Guess then it only make sense to fit genuine ones? |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 260 ![]() ![]() |
I think ours work with Boost alloy wheels, Dave
They will work with Boosts if you use cap head drive flange bolts, as they provide the necessary clearance. I'm using spacers now, which avoids the problem, but ran my Boosts beforehand without issue.
Whist the wheel is a Wolf steel, this picture shows the benefit of cap head bolts (these are the Paddocks HD flanges): ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
Ashcroft work with boosts. Either rotate all dm bolt heads so flat of hex head doesnt stick out or use screw caps Cheers
