Home > Technical > Drive flanges Paddock PM770 vs Ashcroft 859?
hjellemorten
Norway 2007 Defender 90 Puma 2.4 HT Rimini Red
Anyone know the difference between the drive flanges PM770 by Paddock and the 859 by Ashcroft Question
PM770
https://www.paddockspares.com/pm770-heavy-...html?qty=5
859
https://ashcroft-transmissions.co.uk/product/859/
Post #988526 10th Apr 2023 8:14pm
jst
One set was designed, tested by seller, works well of duty material with good properties.
The other is a copy. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #988559 11th Apr 2023 8:33am
hjellemorten
Thanks, just noted that neither one of these seems to work with my original Boost ally wheels. Sad
“These are to be used with Steel wheels or ZU alloys only.”
Guess then it only make sense to fit genuine ones?
Post #988630 11th Apr 2023 6:35pm
ashtrans
Site Sponsor
I think ours work with Boost alloy wheels, Dave
Post #988656 11th Apr 2023 8:13pm
They will work with Boosts if you use cap head drive flange bolts, as they provide the necessary clearance. I'm using spacers now, which avoids the problem, but ran my Boosts beforehand without issue.
Whist the wheel is a Wolf steel, this picture shows the benefit of cap head bolts (these are the Paddocks HD flanges):
 Darren
Post #988657 11th Apr 2023 8:17pm
jst
Ashcroft work with boosts. Either rotate all dm bolt heads so flat of hex head doesnt stick out or use screw caps Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #988681 11th Apr 2023 9:26pm
