Home > Technical > Load capacity (kg) for a 90 (puma/td5)
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
Does anybody know how much weight (kg) a 90 (TD5 or Puma) can carry in the load area?
Ideal to know for a Pickup / Van / CSW if it differentiates.
I had quite a bit to move but didn't want any issues so went with 250-300kg evenly distributed, which was fine but curious how much more I could've gone.
Post #988146 6th Apr 2023 3:51pm
kenzle8a
pretty sure its about 600kg for a TD5 90. They can be up sprung from memory too as my Double Cab was up sprung to 3500kg Max weight so had well over a tonne of payload, I used to stick 500kg bales in the back with no issues.
Post #988149 6th Apr 2023 4:07pm
Dinnu
See the axle weights and gross weights here:
https://topix.landrover.jlrext.com/topix/s...d367/en_GB
Individual axle weights and gross weights cannot be exceeded. So 600kg is a good approximation given that the weight on the rear axle of a 90 is about 800kg when unladen. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #988163 6th Apr 2023 6:40pm
miker
Well, you can put 4 people in the boot with the right combination of seats... I make that an easy 400KG Laughing
Post #988187 7th Apr 2023 7:22am
ibexman
When doing SVA quite a few years back axles we’re rated to 1200 kg each
Post #988188 7th Apr 2023 7:29am
