![]() | Home > Technical > Load capacity (kg) for a 90 (puma/td5) |
pretty sure its about 600kg for a TD5 90. They can be up sprung from memory too as my Double Cab was up sprung to 3500kg Max weight so had well over a tonne of payload, I used to stick 500kg bales in the back with no issues.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
See the axle weights and gross weights here:
https://topix.landrover.jlrext.com/topix/s...d367/en_GB Individual axle weights and gross weights cannot be exceeded. So 600kg is a good approximation given that the weight on the rear axle of a 90 is about 800kg when unladen. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
Well, you can put 4 people in the boot with the right combination of seats... I make that an easy 400KG
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2962 ![]() ![]() |
When doing SVA quite a few years back axles we’re rated to 1200 kg each
