Home > Td5 > Transfer box drivers side mount
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Does anyone have any idea how to reassemble the mount to the transfer box. I have the welded on mounts and a square rubber mount I just can’t see how they are assembled. Have tried loosening the gearbox mount and jacking the box up but still won’t fit
Post #987684 2nd Apr 2023 9:07pm
Sicastle71
These are the mounts on mine
Post #987686 2nd Apr 2023 9:11pm
rallysteve
A useful tip here is that the threaded stud on the gearbox mount has a torx head which can be unscrewed with a female torx socket (E-12 or similar) which makes fitting a lot easer Thumbs Up
Cheers,
Post #987706 3rd Apr 2023 8:04am
geobloke
And if it does not have a Torx head on it, as some pattern parts do not, you can use the two nut-trick to remove the stud and replace it. Thumbs Up
Post #987713 3rd Apr 2023 9:33am
