Home > Td5 > Transfer box drivers side mount |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 127 |
Click image to enlarge These are the mounts on mine |
2nd Apr 2023 9:11pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
A useful tip here is that the threaded stud on the gearbox mount has a torx head which can be unscrewed with a female torx socket (E-12 or similar) which makes fitting a lot easer
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
3rd Apr 2023 8:04am |
And if it does not have a Torx head on it, as some pattern parts do not, you can use the two nut-trick to remove the stud and replace it.
3rd Apr 2023 9:33am |
