Home > General & Technical (L663) > Grille in hard top bulkhead |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
The whole bulkhead is. Not sure about just the grille.
1st Apr 2023 2:19pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1763 |
The grill is a separate piece to main bulkhead
1st Apr 2023 4:03pm |
GeeWhizRS Member Since: 01 Apr 2023 Location: Preston Posts: 6 |
Is the bezel just a press fit?
1st Apr 2023 5:15pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2834 |
No it's bolted on, but you can remove it.
It doesn't make much difference to the view in the rear view mirror, which is mostly of the spare wheel. But you can see enough to make it worthwhile. |
1st Apr 2023 5:32pm |
Thanks for that. There was nothing ont’internet I could find about it. 👍
1st Apr 2023 7:15pm |
BolloB Member Since: 30 Apr 2023 Location: Scotland Posts: 3 |
Hi, did you manage to remove the grill? My one arrived and I’d like to retain the bulkhead but remove the grill. I was thinking if I could remove the grill bezel, remove the actual grill then replace the bezel then that would be the neatest solution. Any advice on how to remove the bezel without breaking it apart? Cheers
30th Apr 2023 4:38pm |
Mine hasn’t arrived yet. If there are no obvious fixings visible then assuming it’s not all moulded as one part I could image it being a push fit from both sides. Are there no fixings visible?
30th Apr 2023 6:46pm |
There isn’t anything obvious. I’ll take some pictures and will share tomorrow
30th Apr 2023 7:20pm |
If there is a visible gap between the grille surround and the main bulkhead then it probably clips together in two pieces. Probably very easy to it up trying to remove it. Look forward to the pics though.
30th Apr 2023 9:00pm |
Okay I’ve finally had a go at removing the bezel around the grill. It was surprisingly easy and nothing ended up being broken. The bezel is attached to the grill via metal clips that pop out easily with a trim tool. The grill can then be removed. Note that the bezel clips into the grill meaning when you remove the grill the bezel has nothing to clip back into. I captured some pictures. Hopefully you can see them in the gallery
14th Aug 2023 7:33pm |
Nice one mate. Thanks for taking the time to post. 👌
14th Aug 2023 8:29pm |
