![]() | Home > P400e Area (L663) > Brake disc & calliper / pad setup? |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2770 ![]() ![]() |
Hi folks,
Just noticed something and not sure if it's odd or not... Car had been sat in the wet for a couple of days so the usual bit of surface rust had accumulated on the discs - nothing to worry about but it made clear that the callipers/pads are very much only making contact with a small part of the disc. (see pic below) I know the P400e has the big discs from e.g. the V8 but does is this really how it's supposed to be? Anyone else got the same / different? ![]() Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 293 ![]() ![]() |
Something wrong there I think. Here’s a pic of one of my front discs:
Interesting - a few random pics from the internet suggest the same.
If you get a moment, could you send over a pic of your callipers? Possibly I have the right callipers (how could they get that wrong?!) but just the wrong pads or something… Might take a wheel off for a closer look… Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Hope these help, not easy to get good shots. Bear in mind this is the V8:
![]() ![]() ![]() ![]() Are both discs the same? |
Any news David? Am curious to know what the issue turns out to be.
Am investigating a bit further - could just be that gentle braking only clears part of the disc area.
Am seeing what luck a bit of more “aggressive” braking has over a bit of time. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
