Home > Technical > 300 TDI 10as immobilizer removal
Darren
United States 1998 Defender 110 300 Tdi CSW Coniston Green
Hello, I am new to the Defender world as of yesterday. I picked up my new to me 1998 Defender 110 from the port after importing it to the US. Problem is it wont start now. The previous owner said he bought the truck without the security fob and never needed it. So somewhere from the UK to the US the truck might have rearmed itself and will not let me start it up. I have narrowed it down to the 10as or the ignition switch. Instead of wasting time with them I would rather just replace one and remove the other. I know this is a touchy subject because of theft. So if you can help shoot me a message or shoot me some ideas on what else I can try.
Thanks!
Post #986815 25th Mar 2023 8:13pm
There is a factory supplied plug in unit to remove the spider unit which is what usually causes the problems.
It's mounted in the battery box. drill out some rivets and you can access it. Mine used to play up, I took it out and there were lots of dry solder joints on the plug. re-soldered it and it was faultless after that.
Post #986826 26th Mar 2023 7:27am
donmacn
A car I’m working on now has an immobiliser, and I’ve bought the factory bypass plug.
But if you’re “over there” and getting the plug will take a while, I know I also read something at the time I was researching this about which wires to bypass. It might give you a short term fix while waiting for the plug to arrive - which is not expensive, and makes the job a lot neater.
I’d PM if I’d kept that info, or where I found it, but once a realised a plug was easily available I’m afraid I didn’t make a note. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #986839 26th Mar 2023 9:02am
Darren
Do you have a link to the factory plug option?
Post #986908 26th Mar 2023 5:32pm
donmacn
Honestly, a Google for “300Tdi immobiliser bypass” will do the job. On this side of the pond it throws up lots of results. Donald
in the past..
Post #986919 26th Mar 2023 6:40pm
PaulMc
AMR4956
. Paul.
Post #987024 27th Mar 2023 3:49pm
