Home > Technical > indicator do only work when hazard swith is engaged
Karba78
France 2000 Defender 90 2.5 TD SW Zermatt Silver
Hello
had an issue with my indicator lights, they would not turn on , nor left nor right. did change the relay and the hazard switch. they do function left, or right only if the hazard switch is engaged.
Also if the hazard switch is engaged; i have no indicator / hazard lights functioning.
i can drive; but can't use hazard
anyone had the same issue ?
thks
Post #986795 25th Mar 2023 4:57pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
The hazard switch may be faulty.
I put a new one in when I upgraded to LED and indicators wouldn’t work.
Stripped back everything.
Put old switch back on and it was fine.
There is a lot of poor quality parts out there don’t trust they work.
Good luck.
Post #987313 30th Mar 2023 8:32am
