![]() | Home > General & Technical (L663) > 4WD system question |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 79 ![]() ![]() |
Sounds faulty to me.
I had to reverse up a steep road that was basically sheet ice a few months ago (driver coming up the hill in his van got stuck and slid back down and blocked the road). The 4WD worked flawlessly basically turning one wheel at a time without any interaction from me. I left it in Comfort Mode (I don't have Auto Terrain Response) as it was pitch black, I was late for a flight and couldn't remember how to get Low Traction Launch or any other fancy stuff! I learned my lesson and a couple of days later spent a good couple of hours selecting different programs and in and out of low ratio until I could do it all without having to think and stare at the screen. When I did the Landrover Experience Day in the Defender we spent most of it on Low Ratio but everything just worked. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3074 ![]() ![]() |
The vehicle has only done 3,000 miles. l am not sure if there's any way to test it, there's no warnings on the dash.
If it was only in 2WD wouldn't you get the warning come up? How could l test the 4WD? Perhaps l need to find another muddy field! |
steam_simon Member Since: 24 Sep 2022 Location: London Posts: 95 ![]() ![]() |
I'm no expert but there is a diff lock between the front and rear axles as standard. If you bring up 4WD in the IDD it will show whether this is locked or not. I suspect that in Comfort it is only unlocked and therefore the rear wheels will spin. If you had selected an off-road mode, then diff lock should have allowed the power to go to the front wheels (I think!).
You could well be correct.
l'll try it again tomorrow, there's a local farmer that l know, will let me on his land. l will report back when l've tried it out. |
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 ![]() ![]() |
The center locker works in comfort mode. If it’s anything, it’s not that. Even if it didn’t lock, TC would kick in after the wheels slip.
l've not tested it yet. l'll report back when l can get on to a muddy field with it.
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3461 ![]() ![]() |
Yes you definitely get a warning, my 90 had issues with 2WD warnings popping up on the dash, though it was in 4WD. 24MY 90 D250 HSE, Tasman Blue |
