Home > General & Technical (L663) > 4WD system question |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 79 |
Sounds faulty to me.
I had to reverse up a steep road that was basically sheet ice a few months ago (driver coming up the hill in his van got stuck and slid back down and blocked the road). The 4WD worked flawlessly basically turning one wheel at a time without any interaction from me. I left it in Comfort Mode (I don't have Auto Terrain Response) as it was pitch black, I was late for a flight and couldn't remember how to get Low Traction Launch or any other fancy stuff! I learned my lesson and a couple of days later spent a good couple of hours selecting different programs and in and out of low ratio until I could do it all without having to think and stare at the screen. When I did the Landrover Experience Day in the Defender we spent most of it on Low Ratio but everything just worked. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
22nd Mar 2023 3:53pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2925 |
The vehicle has only done 3,000 miles. l am not sure if there's any way to test it, there's no warnings on the dash.
If it was only in 2WD wouldn't you get the warning come up? How could l test the 4WD? Perhaps l need to find another muddy field! |
22nd Mar 2023 7:55pm |
steam_simon Member Since: 24 Sep 2022 Location: London Posts: 91 |
I'm no expert but there is a diff lock between the front and rear axles as standard. If you bring up 4WD in the IDD it will show whether this is locked or not. I suspect that in Comfort it is only unlocked and therefore the rear wheels will spin. If you had selected an off-road mode, then diff lock should have allowed the power to go to the front wheels (I think!).
22nd Mar 2023 8:11pm |
You could well be correct.
l'll try it again tomorrow, there's a local farmer that l know, will let me on his land. l will report back when l've tried it out. |
22nd Mar 2023 9:21pm |
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 |
The center locker works in comfort mode. If it’s anything, it’s not that. Even if it didn’t lock, TC would kick in after the wheels slip.
26th Mar 2023 12:14pm |
l've not tested it yet. l'll report back when l can get on to a muddy field with it.
26th Mar 2023 6:43pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
Yes you definitely get a warning, my 90 had issues with 2WD warnings popping up on the dash, though it was in 4WD. 24MY 90 D250 HSE, Tasman Blue |
26th Mar 2023 7:34pm |
