Home > Puma (Tdci) > RRC2970/1 Heavy Duty (military?) Bumperettes |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 |
yes they do fit i have them on my one removed from my td5
not sure on the bolts as my ones came from ebay and i got the bolts from work Dan |
31st Jan 2009 11:04pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
Hi Which ones are these? I got some and they do not fit straight up! cheers Mk |
31st Jan 2009 11:17pm |
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 |
First image (with part number) I suspect is the "real" LR part and the other is supposed to be the same but looks a different fitting. Trevor Wright '08 90 TDCi/TD4 XS SW Last edited by Trevor Wright on 1st Feb 2009 11:03am. Edited 1 time in total |
1st Feb 2009 9:18am |
i have the ones on the left
made by land rover not after market they came in a land rover parts box like all things defender they did fit the TD5 better on the TDCi i had to use the bolts to pull them into place yes you can stand on them also stops any little bumps in car park |
1st Feb 2009 10:22am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Only problem is you have to drill the cross member for the inner mounting bolts 2.4 90 XS
3rd Feb 2009 5:55pm |
From what I've discovered thus far, these RRC2970/2971 bumperettes were developed specifically for the military Defender XD (i.e. "Wolf") and not, as such, intended for other Defenders. However I'm told that as long as you get the Genuine Land Rover examples and not the pattern parts sold by many people, then they fit the Td5 without a problem and fit the Puma/TDCi - I believe without any drilling. I did ask a dealership and they really didn't know but said they were not listed as a 2008 Puma part. I could try asking LR at Solihull, not sure if they'd respond. Trevor Wright
'08 90 TDCi/TD4 XS SW |
4th Feb 2009 9:34am |
Trevor, you do have to drill the cross member Bearbach's broshure tells you that,the bumperettes were originaly fitted to all military spec LR's from the sixty's along with the front ones. 2.4 90 XS
4th Feb 2009 9:59am |
you do not have to drill the rear crossmember at all
just make sure they are wolf ones and they will fit fine and made buy land rover the hole are predrilled in the cross member daniel |
4th Feb 2009 10:26am |
Dan, things must have changed and Bearmach haven't updated there cat.and as you say they are gen parts. 2.4 90 XS
4th Feb 2009 11:03am |
Checked the Bearmach catalogue and it says:
"HEAVY DUTY BUMPERETTES Suitable for Defender, these bolt directly on to the cross member replacing the grab handles. Will also fit Series 2/3 vehicles but requires drilling of cross member. Made from heavy gauge steel and powder coated for durability. Will fit with Spare Wheel Carrier BA 132" We have no grab handles on the Puma but I'm guessing the holes are still there. Trevor Wright '08 90 TDCi/TD4 XS SW |
4th Feb 2009 11:27am |
