Home > Puma (Tdci) > RRC2970/1 Heavy Duty (military?) Bumperettes
Trevor Wright
Do the RRC2970/2971 Heavy Duty Bumperettes fit the Puma Defender and do you know if they come from suppliers with the 4 M10 (I think) bolts/nuts required. I believe these are as fitted to military Defenders?
Also - I guess they are strong enough to stand on if required?
Thanks Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #6729 31st Jan 2009 4:02pm
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
yes they do fit i have them on my one removed from my td5
not sure on the bolts as my ones came from ebay and i got the bolts from work
Dan
Post #6739 31st Jan 2009 11:04pm
MK
Dan
Hi
Which ones are these? I got some and they do not fit straight up!
cheers
Mk
Post #6740 31st Jan 2009 11:17pm
Trevor Wright
First image (with part number) I suspect is the "real" LR part and the other is supposed to be the same but looks a different fitting. Trevor Wright
Post #6748 1st Feb 2009 9:18am
Daniel TD5
i have the ones on the left
made by land rover not after market they came in a land rover parts box
like all things defender they did fit the TD5 better on the TDCi i had to use the bolts to pull them into place
yes you can stand on them
also stops any little bumps in car park Rolling with laughter
Post #6752 1st Feb 2009 10:22am
Grockle
Only problem is you have to drill the cross member for the inner mounting bolts 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6829 3rd Feb 2009 5:55pm
Trevor Wright
From what I've discovered thus far, these RRC2970/2971 bumperettes were developed specifically for the military Defender XD (i.e. "Wolf") and not, as such, intended for other Defenders. However I'm told that as long as you get the Genuine Land Rover examples and not the pattern parts sold by many people, then they fit the Td5 without a problem and fit the Puma/TDCi - I believe without any drilling. I did ask a dealership and they really didn't know but said they were not listed as a 2008 Puma part. I could try asking LR at Solihull, not sure if they'd respond. Trevor Wright
Post #6860 4th Feb 2009 9:34am
Grockle
Trevor, you do have to drill the cross member Bearbach's broshure tells you that,the bumperettes were originaly fitted to all military spec LR's from the sixty's along with the front ones. 2.4 90 XS
Post #6861 4th Feb 2009 9:59am
Daniel TD5
you do not have to drill the rear crossmember at all
just make sure they are wolf ones and they will fit fine and made buy land rover the hole are predrilled in the cross member
daniel
Post #6863 4th Feb 2009 10:26am
Grockle
Dan, things must have changed and Bearmach haven't updated there cat.and as you say they are gen parts. 2.4 90 XS
Post #6866 4th Feb 2009 11:03am
Trevor Wright
Checked the Bearmach catalogue and it says:
"HEAVY DUTY BUMPERETTES
Suitable for Defender, these bolt directly on to the cross member replacing the grab handles. Will also fit Series 2/3 vehicles but requires drilling of cross member. Made from heavy gauge steel and powder coated for durability. Will fit with Spare Wheel Carrier BA 132"
We have no grab handles on the Puma but I'm guessing the holes are still there. Trevor Wright
Post #6867 4th Feb 2009 11:27am
