Home > Technical > Replacing bolts and nuts
Niels906
Netherlands
Probably a silly question, but how would I go about in replacing bolts and nuts. Do I always have to replace them with original LR parts, or can I order generic bolts and nuts. For instance I am looking to replace the prop shaft bolts. What kind do I choose? Is there an easy way to replace them? Thank you all!
Post #984874 8th Mar 2023 8:44pm
sako243
Ideally like for like I'd say unless you know better. Most will be stamped with a tensile strength (E.g. 8.Cool and usually thread matters especially if it's fine due to the clamping force it exerts.
Propshaft bolts are a bit special because of the space they work in - think they're still an imperial thread despite having a metric head size (or it's close enough). Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #984875 8th Mar 2023 8:49pm
Propshaft are 3/8" UNF with a 9/16" AF head.
The front axle still has fasteners with BS, UN and metric threads.
Generic are fine as long as they are the same or equivalent size and grade.
Post #984879 8th Mar 2023 9:08pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
When refurbing my axles recently I found most of the bolts were grade 10.9 A lot of the bolts are also bi-hex and also not quite standard lengths. If you get the bolts as per part numbers they also have threadlock on them. I was going to look at using fixings I had at home but the tended to be 8.8, hex head and fully threaded.
Post #984890 8th Mar 2023 11:25pm
It's never a good idea to replace a bolt (which by definition is part-threaded) with a setscrew (which by definition is fully-threaded).
Generally the head style doesn't matter in engineering terms. Landrover are very prone to using flange head fasteners because on a production line they're cheaper than a hex head with separate washer.
Post #984891 8th Mar 2023 11:44pm
Niels906
Netherlands
Thanks all, after your advice I decided to go for identical replacement parts. Thanks!
Post #985544 14th Mar 2023 5:55pm
