Home > Technical > Replacing bolts and nuts |
Niels906 Member Since: 04 Jul 2020 Location: Bussum Posts: 44 |
Probably a silly question, but how would I go about in replacing bolts and nuts. Do I always have to replace them with original LR parts, or can I order generic bolts and nuts. For instance I am looking to replace the prop shaft bolts. What kind do I choose? Is there an easy way to replace them? Thank you all!
8th Mar 2023 8:44pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17463 |
Propshaft are 3/8" UNF with a 9/16" AF head.
The front axle still has fasteners with BS, UN and metric threads. Generic are fine as long as they are the same or equivalent size and grade. |
8th Mar 2023 9:08pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
When refurbing my axles recently I found most of the bolts were grade 10.9 A lot of the bolts are also bi-hex and also not quite standard lengths. If you get the bolts as per part numbers they also have threadlock on them. I was going to look at using fixings I had at home but the tended to be 8.8, hex head and fully threaded.
8th Mar 2023 11:25pm |
It's never a good idea to replace a bolt (which by definition is part-threaded) with a setscrew (which by definition is fully-threaded).
Generally the head style doesn't matter in engineering terms. Landrover are very prone to using flange head fasteners because on a production line they're cheaper than a hex head with separate washer. |
8th Mar 2023 11:44pm |
Thanks all, after your advice I decided to go for identical replacement parts. Thanks!
14th Mar 2023 5:55pm |
