- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
geobloke
ben1823 wrote:after taking my 2006 td5 90 on a Greenlane in the last 2 weeks, I have encounter an issue with when changing gear the revs of the engine will stay the same and only drop after a good 20 seconds off the throttle.
some people have said crank position sensor, I am clueless so any ideas would be helpful.
As above. It sounds like either the clutch position switch is faulty or you have air in the switches orifice.
To check, unplug the switch and go for a drive. The ECU will no longer modulate the RPMs when the clutch is used. The anti-stall will not work, but you can continue unhindered.
The part is number 27: MSK500010 - You cannot use a Puma clutch switch, only a TD5 one.
https://www.lrworkshop.com/diagrams/land-r...ipes_53771
9th Mar 2023 12:09pm |
