Home > Td5 > td5 engine issue |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5790 |
If you have a nanocom or similar check if ecu thinks you are in high or low, and if the clutch is up or down.
6th Mar 2023 5:19pm |
cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 55 |
Hi had something the same turned out to be the switch on top of the clutch pump was leaking take of the plug and check it for fluid
9th Mar 2023 7:06am |
As above. It sounds like either the clutch position switch is faulty or you have air in the switches orifice. To check, unplug the switch and go for a drive. The ECU will no longer modulate the RPMs when the clutch is used. The anti-stall will not work, but you can continue unhindered. The part is number 27: MSK500010 - You cannot use a Puma clutch switch, only a TD5 one. https://www.lrworkshop.com/diagrams/land-r...ipes_53771 |
9th Mar 2023 11:09am |
