Home > Puma (Tdci) > 2015 Defender Console Light Issue
roche1800
The problem:
Hot/Cold dial light doesn’t work initially but after turning and the dial it sort of works
Question:
How to do I get behind? Do I pull the dial hard or …
Has anyone experienced this?
Many thanks
Post #984333 3rd Mar 2023 8:19pm
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
You can remove the center part of the dash where the radio etc is seated by undoing the two torx screws and unclipping it all and pulling it forward. You should then easily be able to access the back of those dials.
Post #984431 5th Mar 2023 8:27am
wyvern
as above - but the lights are in the white mouldings left in the facia inside the dash . .. there are a lot of posts on how to change these if you do a quick search
such as here - https://www.defender2.net/forum/topic16996...=dash+bulb
its a ’sticky’ on the forum...
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #984445 5th Mar 2023 10:36am
hornet
As a supplement, I don't know the price of the Land Rover bulbs, but you can usually get 10 of them with the description Osram W1.2W 12V W2x4.6d (2721) online for a very good price.
Post #985718 16th Mar 2023 9:15am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
From memory I fitted LED bulbs to my 2.2, much better illumination, possibly used these in White
https://www.autobulbsdirect.co.uk/286-t5-l...86led.html NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #985757 16th Mar 2023 1:27pm
HardCharger
Do they distribute lights equally? The earlier LED units had bright "hotspots" from where the output was focused and dismal light in the surrounding areas
Post #985869 17th Mar 2023 3:34am
NormanD
No issues at all, I used LED286W
2015 110 XS Utility
Post #985893 17th Mar 2023 8:47am
