Home > Puma (Tdci) > First shipment MY2012?
Page 5 of 5 <12345
DefenderOfTheEarth
Some beauties on here! Love that double cab!
Any comments on the new engine guys (and possibly gals?!!)? Defender 110XS SW gone... now VW California 180 4 Motion.
Post #102668 26th Nov 2011 5:29pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
There's a write up on the 2012 Defender in this months LRO, as well as the 2012 RRS, FFRR and Disco 4. Didn't have time to read it properly, but had a quick glance at it...
The DPF has been relocated, it's near the downpipe, and can be regenerated in about 10 mins at speeds above 20mph - apparently farmers have been testing them for 8 months and not had a problem.
Also it mentions the new acoustic engine cover, other under bonnet gubbins -vac pump relocated, new design and routing for the coolant hoses, and that all the dashboard lights are now LED. There was a lot more mentioned, but was in a rush and already late so didn't have time to read the whole article.
Post #102802 27th Nov 2011 2:07pm
Axel
Germany 2012 Defender 90 Puma 2.2 SW Keswick Green
Well ... having done about 400 miles now I must admit that it seems to be more than okay .... More quiet and less characteristic than the Td5 or even the 2.4 .... but seems more lively and nippy .... However, I am still taking it a bit easy on the first 700-800 miles .... But so far I am not at all disappointed!!! Wink
Thumbs Up Best Regards,
Axel
Post #104834 5th Dec 2011 7:56pm
22900013A
I have seen a few 2012s now, with the black canvas backs on 130s etc. Usually on transporters of course. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #104838 5th Dec 2011 8:01pm
Paul Rover
Having just covered over 100 miles in mine I would agree re being more lively and nippy - certainly more so than my old 300TDi and the heating system, now the weather has turned colder is brilliant!! Very Happy
Post #104847 5th Dec 2011 8:17pm
Doublecabdefender
United Kingdom 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
Just a quick update, have just covered 500 miles, all is well apart from rain and mud getting into the rear foot wells seemingly from underneath the doors somewhere.
Frantic squeaking and rattling from the rear seats as well.
The dealer has just called me to say, the rear doors had to be removed and re-aligned, and all the seats came out, then re-tightened all the mounts ect - all is ok, no squeaks or rattles.
They thought they would take her out for a test drive to check all is good, the engineer noted a clunking, come grinding noise from somewhere under the vehicle. Back on the ramps and 40 mins later. they located a 'beam' their words not mine that hadn't been welded up correctly that seems to be moving! Rolling Eyes
Dealer having to speak to Land Rover directly to see how to tackle the problem!
Do Land Rover ever check anything prior to it leaving the factory? 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
''I can resist everything except temptation. ''
Post #105539 8th Dec 2011 3:20pm
Paul Rover
Makes you wonder. I had to call Land Rover assist out yesterday as the engine malfunction light came on. Big Cry
This was due to -
1. Airflow sensor multi plug not locked in.
2. Lower charge hose not correctly fitted.
Haven't covered 200 miles yet.
Otherwise everything fine! Very Happy
Post #105544 8th Dec 2011 3:37pm
Sockpuppet
Regardless that would be going back and getting rejected if it was my vehicle.
Post #105545 8th Dec 2011 3:44pm
Doublecabdefender
I did that with the last MY57 DCPU XS, owned it for nine months but it spent six at the dealers getting sorted. In the end I gave up, rejected it and they gave me a new D3 TDV6 SE fully loaded in its place.
Three years down the line, as much as the D3 was a great vehicle my heart was never in it, much prefer Defenders.
So I am loathed to reject this one, I feel I must give them some leeway to sort out the probs, apart from that I am smitten and couldn't part with her Very Happy 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
Post #105548 8th Dec 2011 3:55pm
Doublecabdefender
Ok great news, Land Rover back, no squeaks, rattles or leaks. The receptionist obviously didn't get the right message, the only welding that was necessary was a small spot weld which had failed on one of the rear seats - hence the mouse squeaking noise.
Very happy, extremely quiet cab now. Very Happy 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
Post #105785 9th Dec 2011 2:17pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
“Do Land Rover ever check anything prior to it leaving the factory?”
No.... What are they gonna do if they find anything wrong? Halt an assembly line? Have a team of electricians, welders, painters etc. on standby to fix any faults?
They let the vehicles go out as is, the dealer can modify production errors or the customer can discover any faults for the dealer to fix; the dealer’s expenses have already been built into L-R’s retail price.
Yes, I know some manufactures adopt the approach of “get it right before it reaches the dealer”, but Land Rover isn’t one of them.
Peter
Post #106008 10th Dec 2011 4:38pm
Happyoldgit
Peter
Very true. Some dealers are better than others but the ethos is often to let the customer discover any faults and then rectify them on demand ....not before trying the "but they're all like that Sir" get out first. Steve.
http://forums.lr4x4.com
Post #106025 10th Dec 2011 5:45pm
rossy
bloody ridiculous. It took them 2 years to start putting the 2.4 together remotely properly. Now there's a new engine it seems they are on the learning curve again. I really thought the above problems had been ironed out by now.
I've often watched 'megafactories' on one of the discovery channels where they show you how Ferraris, Aston Martins etc are built and wished they'd feature the Defender factory but I think it would be too embarassing for LR cos it would be like The Chuckle Brothers !
Post #106066 10th Dec 2011 9:44pm
The Boy
Peter
How bloody true is that. The "but they're all like that sir" really gets up my nose and it is the first line they use. I am sick of hearing it
Post #106113 11th Dec 2011 9:41am
Page 5 of 5 <12345
