Home > Puma (Tdci) > drivers door lock fault / central locking bouncing |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1786 |
Hopefully someone can suggest a potential fix:
Today after driving I couldn't open drivers door, locked and unlocked door with fob and button but still no joy. Undignified exit through passenger side, managed to pull top of door card away and undid all of the control rods and managed to fiddle with lock and got door to open. The actuator 'bounces' when disconnected, swapped for a known good one - still the same. Wiring through pillar looks good. All other doors work 100% and all locks are always well lubed. Reconnected everything and it now locks and unlocks off the fob OK. Probably unrelated but the revs are hanging with the clutch depressed as well. Any ideas anyone? Cheers Keith |
13th Feb 2023 7:32pm |
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 |
I had the same problem on my passenger side. It only happened in the cold and once the temperature went back up it was ok. I did spray some wd40 into the peg as well. No idea if that helped or if it was a cold issue. |
21st Feb 2023 7:11am |
