![]() | Home > Puma (Tdci) > Door Locks hard to unlock |
dannyragsdale Member Since: 07 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 ![]() ![]() ![]() |
All 3 of my doors are difficult to unlock. I put the key in and then have to pull it back ever so slightly in order for it to turn. Takes several tries to get it just right every time and it's getting old. Anybody else have this issue or know how to remedy it? Not keen on replacing the locks because I don't want to replace the ignition either.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2273 ![]() ![]() |
Worth using some graphite powder to lubricate the locks and see if that improves things.
Tried the graphite powder and helped minimally on one of the door locks. Any other suggestions?
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
My drivers and rear door lock barrel were totally useless. Couldn't even get a key into either. Full of corrosion - I actually thought they had been super glued.
I took the locks off, then slowly stripped them apart using brake cleaner and WD40. Awful job 😪. Cleaned every bit careful to not let all the little sliders in the barrels fall out, greased and refitted. Both now working as expected. 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
