Home > Puma (Tdci) > ABS Front sensor pickup
TC909
I've just had the swivel pins, stub axles, chrome balls done on my Puma by a local garage.
500 miles in and the ABS & TC light are on permanently now.
I disconnected the front sensors, both read the same 1149ohms.- Looks like this is correct online.
Sensors seem clean and seated well in the hub...
Is there a pickup in the hub the sensor matches too? Or maybe one of the sensors is for some reason now faulty?
Anything else I could check before ordering a new sensor?
Post #981511 6th Feb 2023 4:21pm
BrickBox
Possibly just erase the fault code to reset. See if that works. Hopefully it won’t re-occur. 2008 2.4 110 Utility Station Wagon XS.
Post #981516 6th Feb 2023 4:36pm
Bluest
The trigger ring is part of the CV joint, so if that wasn’t replaced with a non-abs one then that shouldn’t be the problem. 2007 110 TDCi Station Wagon XS
Post #981521 6th Feb 2023 5:33pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
ABS sensor Pickup
Hello,
Couple of things to try, Remove the sensor from the hub, and reseat- sometimes they stick in the small cage thing that is supposed to hold them still.
Check the spacing on the end of the halfshaft/CV if its not correct it can make the car throw a wobbler.
If it was done by a garage I'd probably just punt it back to them to check.
Chris
Post #981670 7th Feb 2023 3:31pm
TC909
Thanks for the info, after cleaning & reseated both and I went for a longer drive and the TC light is now out.
Post #981748 8th Feb 2023 11:09am
