![]() | Home > Technical > 27mm or 21mm nuts |
Landowner Member Since: 06 Jan 2023 Location: Somerset Posts: 76 ![]() ![]() ![]() |
I’ve seen adverts for defender wheel nuts size 27mm and 21mm. Mine are 27mm on steel wheels.
I need a set of nuts for new boost alloys, will both 27 / 21mm fit? Obviously different wrench size to use them! Thank you |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
My boosts are on 27mm nuts. My range rover alloys were 27mm too.
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 853 ![]() ![]() ![]() |
I thought that all genuine Defender wheel nuts were 27mm?
Jim |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17615 ![]() ![]() ![]() |
Given that the studs are M16 find thread, I don't see how a 21mm AF nut would be possible.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
1 and 7 may look very similar, so could be a typo during data entry.
27mm is the normal size for Defenders up to 2016. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
