Home > Technical > 27mm or 21mm nuts
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
27mm or 21mm nuts
I’ve seen adverts for defender wheel nuts size 27mm and 21mm. Mine are 27mm on steel wheels.
I need a set of nuts for new boost alloys, will both 27 / 21mm fit? Obviously different wrench size to use them!
Thank you
Post #981277 4th Feb 2023 6:54pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
My boosts are on 27mm nuts. My range rover alloys were 27mm too.
Post #981278 4th Feb 2023 7:18pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
I thought that all genuine Defender wheel nuts were 27mm?
Jim
Post #981312 5th Feb 2023 7:54am
Given that the studs are M16 find thread, I don't see how a 21mm AF nut would be possible.
Post #981316 5th Feb 2023 8:23am
discomog
M16, ISO 4032 metric nuts have an minimum across flats dimension of 23.67mm. I wouldn't like to think that my wheels were held on by 21mm AF nuts, a material thickness of only 2.5mm would not give me much confidence. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #981317 5th Feb 2023 8:45am
Dinnu
1 and 7 may look very similar, so could be a typo during data entry.
27mm is the normal size for Defenders up to 2016. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #981318 5th Feb 2023 8:48am
