Home > Tdi > 300Tdi air box
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
300Tdi air box
Hi all
Currently helping out a friend sort his Defender 90 300Tdi.
For whatever reason a previous owner removed the Land Rover air box and fitted a weird carbon fibre replacement that is sealed airtight with gaffer tape…
My question is it appears to me that the air filter housing in the Discovery 200Tdi is the same as the one on the Defender 300Tdi. This includes the 2 spring metal securing straps that I am struggling to find.
Any one know if the above is the case? Disco parts are, for some reason, a lot cheaper than a defender parts?
Jim
Post #980850 1st Feb 2023 7:47pm
htb2
Wales
Might have most of the parts in the shed, I can check in the morning if you would like.
I think the rear discovery 200tdi mount is the same, front prob different as it's angled to fit the angled part of the inner wing IIRC.
Post #980853 1st Feb 2023 7:57pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
My early 300tdi has the cylindrical steel can air filter housing, mounted in the band clamps and sat on 4 rubber bush feet.
I actually use the 200tdi filter as it has the plastic swirl shield fitted that the 300tdi version doesn't. It fits the same and is better IMO.
Post #980996 2nd Feb 2023 6:10pm
donmacn
^^^ I know the 300 set up fine, but I don’t think I’ve ever seen the 200 or that swirl shield.
Any chance you could post some pictures?
I’m googling it, but no great luck so far. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #980998 2nd Feb 2023 6:49pm
htb2
Wales
Donald. IIRC there were two different housings on 200tdi engines well in discoveries anyway, one had the swirl fan on the filter and one without.
On an aside Donald I have got the full EGR valve off of that 300tdi engine if you are still want one, I will be back up Inverness /Culloden area in late Apr/ beginning May
Post #981024 2nd Feb 2023 8:52pm
I Like Old Skool
200tdi NTC6660
300tdi ESR2623
Post #981050 2nd Feb 2023 11:20pm
donmacn
Thanks for the part numbers. I’ve found them OK. But perhaps I misunderstood what was being said above.
I took it from the earlier posts that the actual filter housings were different - but that the 200Tdi one included swirl fins, and would fit in the same location as the 300tdi canister.
If it was just that the 200Tdi filter inserts had fins, but the 300s didn’t then that makes sense. I hadn’t known that. I wonder why they changed? Manufacturing costs? Are they the same in every other respect?
I asked for pics because I thought the canisters were different. I can get loads of the externals but not the insides - but if there’s nothing to see there because the fins are on the insert, then that’s obviously not necessary. Donald
in the past..
Post #981075 3rd Feb 2023 10:33am
