Home > Puma (Tdci) > Help! Nakatanenga door damper bewilderment
ZeDefender
Please can someone tell me what the two flat rectangular metal pieces are for (about 2 x 1 inches and with 2 holes in them). Are they spacers? The holes are much bigger/longer than on the main damper assembly and barely line up. Do I need them?
Everything was going smoothly (all ready to drill the rivet holes) until I found there were no instructions Sad
I cant see them on the Nak. website photo Sad There is also a spare bolt...
I really want to get this fitted today (not raining).
Any help (but not the sarcastic kind) will be met with God-like worship Bow down
Cheers,
Matt Tell someone you love them today because life is short.
Post #94322 15th Oct 2011 7:33am
midmaik
United States
A picture would help.
Post #94328 15th Oct 2011 8:24am
BigRuss
They are spacers to put behind the bracket that attaches to the wheel box,
They move it out to enable the doo to open further.
I put both of them in with no problems Thumbs Up Russell
2011MY 110 XS USW Black
Post #94330 15th Oct 2011 8:43am
ZeDefender
Ahaaaaaaa Exclamation Very Happy Very Happy Very Happy
Many thanks to both of you Bow down Bow down Bow down Tell someone you love them today because life is short.
Post #94333 15th Oct 2011 9:46am
ZeDefender
Done! Very Happy
Brilliant piece of kit (obviously cheapskate-LR should have fitted one in the first place...)
Thanks again.
Post #94363 15th Oct 2011 2:06pm
can you take pics pls
Post #94402 15th Oct 2011 6:56pm
ZeDefender
Sort of but the cladding is reassembled now and the grab handle back on - I don't think the pics would be very interesting (just the end of the damper)...
I can say it was very easy (once I figured out exactly what to put where) and will happily give very detailed information to answer any questions Wink
I can also say that even with the spare wheel cover and light guards, the rear door now opens about 89 degrees and stays there, so I shouldn't decapitate the dog again (we live on a slope) Thumbs Up
Post #94406 15th Oct 2011 7:11pm
Well my gas strut has just degassed it's self Censored happens and I'll order a new one on Monday
Post #94421 15th Oct 2011 8:17pm
ZeDefender
Was it a Nak. one? Tell someone you love them today because life is short.
Post #94427 15th Oct 2011 8:34pm
ickle
We used to buy struts from here http://www.stedall.co.uk/acatalog/p138.pdf
Keith
Post #94433 15th Oct 2011 8:51pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Yes, thats a good pint, whos struts do Nak actually use?
I used an Arvin Meritor (Camloc) one on mine as theyre only a few quid and we had a pile laying about at work. But the advantage of these is that you can inflate/deflate them to set the pressure or regas them. The amount Nak charge for one of these I would expect them to have the same facility.
Pete
Post #94468 16th Oct 2011 7:36am
ZeDefender
Pete
You can deflate them (although I find it just right) but the valve is so tiny (and I don't have the right pump/adapter) that you have to send them back to Nak. if you go too far.
Anyone had an "original" Nak. strut (finally know the right name) fail on them?
Post #94469 16th Oct 2011 7:42am
dgardel
Italy
My solution
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #94495 16th Oct 2011 11:41am
ZeDefender
Clever Dick Thumbs Up Tell someone you love them today because life is short.
Post #94501 16th Oct 2011 1:15pm
