Home > Puma (Tdci) > Diff guards
Page 2 of 2 <12
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
That's not my picture, but looking at the Diff guard I have I need to completely remove 2 of the top nuts on the diff housing to fit the bracket and loosen 2 of the bottom nuts to fit the bottom of the bracket.
The bottom of the bracket does not have a full hole that would need to be slid over the diff casing stud/bolt and would only be held by the nut "pinching" it. I'd be reluctant to rely fully on that without the 2 M12 bolts to hold it. If the bottom only slips over on the outside of the nuts, I'd be even less confident.
The Wildbear design is similar.
 Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1020745 10th Jan 2024 5:54pm
Retroanaconda
If you’re fitting wrap around or clamp on diff guards then just remember to take them off periodically to clean behind them, the axle pans are notorious for rusting through and trapped mud etc. will accelerate this.
Post #1020748 10th Jan 2024 6:14pm
andy63
cheers, yes thats the same fitting as the wildbear, which for me was not an easy or straight fwd fit without quite a bit work..
the picture in your post looks to be a bit different...ie I can't see the slots in the plate to allow it to fit over the diff studs and allow it to be nipped up by the nuts
Post #1020749 10th Jan 2024 6:30pm
Page 2 of 2 <12
