Home > Technical > Newbie with clutch issues
fluffy01016
United Kingdom 1993 Defender 90 Other HT Caledonian Blue
Hi to all
Im new to forum and to start off I have a question that I'm hoping someone can help with. I have a 1993/l Defender 90 Hardtop and I've owned for the last 8yrs and covered 70k miles. My biggest issue is that in the last 5 years I've had 4 clutches and need another again Big Cry I've had 2 clutches fitted by a garage, 1 by a landrover specialist and 1 by my brother (a mechanic). I never ride the clutch but do use the Landy for towing a horsebox and 2x 14hh horses. I'm no mechanic but 5 clutches in 5 years seems excessive and there must be another issue causing the clutch to wear
Please help!!!!!!!
Post #94275 14th Oct 2011 6:25pm
MK
Any mods? Puma 110" SW
Post #94310 14th Oct 2011 11:17pm
fluffy01016
MK wrote:
Any mods?
Apart from a stainless sump guard, the Landy is completely standard. Been driving for 17 years and with work I drive 40k miles a year. Never had a clutch changed in any cars except for one evry year in the Landy Crying or Very sad
Post #94321 15th Oct 2011 7:23am
Happyoldgit
What exactly has been the fault with all these clutches - are you saying the plates are wearing out or is it some other failure? Steve.
http://forums.lr4x4.com
Post #94329 15th Oct 2011 8:30am
MK
Is it a Td5 engine? Have you used OE or genuine spare parts?
I assume you changed the pressure plate at some point.
Perhaps the double mass flywheel is not good anymore (internal spings), twisted.
Out of tolerance crankshaft rear flange?
Condition of both (engine and gearbox) input shaft bearings.
Std engine and no remap/chip on?
Check both propshafts are tuning with no issues and you can truly unlock the central diff (beyond the warning light switches off on the intrument panel).
You start to move in 1st and not 2nd gear? Puma 110" SW
Post #94342 15th Oct 2011 10:40am
fluffy01016
It's being predoninantly by the wife at the moment and the symptoms she's describing is high biting point on the pedal and slipping clutch when towing. Not sure on the engine and all I can say is that it's a 1993/l with a 2.5tdi engine (no chip). Clutch only fitted in January (found reciept) and was a genuine Landrover part from Rimmer Brothers. Was done as a kit, so yes the pressure plate was done too. The only thing I can think of is that the 2nd gearbox doesn't work properly and will only engage in high range/no diff lock. I thought this fault might be causing the clutch to go? As for the other issues, I can't say but I'll ask my garage to look into them
Many thanks for the reply
Post #94358 15th Oct 2011 12:39pm
fluffy01016
Clutches just seem to be wearing very, very quickly. I'm ok with basic engine work and I've checked the master & slave cylinder and both look to be ok.
Post #94359 15th Oct 2011 12:40pm
JSG
Could it be a problem with the flywheel? John
2011 Tdci 110 CSW XS
Post #94566 16th Oct 2011 6:56pm
landy andy
1993, so is that 300 Tdi?
Could the wrong push rod be fitted?
Why is the clutch always biting so high?
Pedal not set correct?
Andy
Post #94572 16th Oct 2011 7:08pm
