Home > Td5 > Door Cards
Jordan
United Kingdom 2000 Defender 90 Td5 HT Stornoway Grey
Door Cards
Is there an alternative replacement door cards available, the normal after market ones just done fit very well, and most of the originals I have seen are all busted up.
Post #980382 29th Jan 2023 6:54pm
Mdm
nope the aftermarket one are a very poor they dont fit unless you dremel them in loads of places and the 1st time you take them off they will break all the fixings. then you will end up glueing and screwing them to the door.
the mud stuff rear door one is good though
Post #980391 29th Jan 2023 7:29pm
thinman21
United Kingdom 2004 Defender 90 Td5 HT Belize Green
Have a look at the powerfuluk door cards.
They take a bit of fettling (or did on mine) as I needed to cut away a section but its the bit between the door and the door hinge pillar so can't be seen - depends on which door you have as they fit others ok.
Also have a look at the review on YouTube (The Doctors Garage)
They connect to the doors by using rivnuts instead of the plastic tree arrangements - much better fitting.
Post #980680 31st Jan 2023 2:51pm
