![]() | Home > Td5 > Door Cards |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
nope the aftermarket one are a very poor they dont fit unless you dremel them in loads of places and the 1st time you take them off they will break all the fixings. then you will end up glueing and screwing them to the door.
the mud stuff rear door one is good though |
thinman21 Member Since: 27 Jan 2020 Location: Nottingham Posts: 11 ![]() ![]() ![]() |
Have a look at the powerfuluk door cards.
They take a bit of fettling (or did on mine) as I needed to cut away a section but its the bit between the door and the door hinge pillar so can't be seen - depends on which door you have as they fit others ok. Also have a look at the review on YouTube (The Doctors Garage) They connect to the doors by using rivnuts instead of the plastic tree arrangements - much better fitting. |
