Home > Technical > Dash off question
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Dash off question
I need to pull all the dash off to sort the wipers. New motor etc. Is there any issue with unplugging the instrument cluster for a short amount of time?
Post #980328 29th Jan 2023 2:48pm
markb110
I’ve not had a problem, 2002 TD5.
The odometer reading is via the ECU so that won’t ‘go missing’.
Post #980330 29th Jan 2023 3:04pm
Dinnu
Disconnect the battery first. If you have battery backup alarm, switch ignition on then off and disconnect battery within 15seconds.
Did not have issues with a 2009 Defender. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #980331 29th Jan 2023 3:10pm
Martin
Site Admin
No issue with disconnecting the cluster.
Odometer is stored in non-volatile memory in the cluster (not the ECU as stated above).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #980334 29th Jan 2023 3:23pm
It is possible to replace the entire wiper system without disconnecting the IPAC or removing the dash panel if you remove all the fasteners and simply ease the dash panel away from the bulkhead. removing the dash is however not difficult (although quiet time-consuming) and makes the job more comfortable, though be advised you will inevitably find rust behind it, as well as other jobs you'll want to do at the same time.
If you're in a rush, don't remove the dash. If you have plenty of time and want to do the best job, remove the dash.
Martin, for some reason I thought that the mileage was stored both in the IPAC and the ECM, to make it more difficult to "clock" a vehicle by swapping the IPAC. Am I imagining this? Thanks.
Post #980336 29th Jan 2023 3:36pm
TamarBlue11
Thanks guys, sorry should of said its on a Puma.
Post #980344 29th Jan 2023 4:07pm
TamarBlue11
Having to do this job in stages but have stripped everything to the point the dash is resting on just with the instrument cluster plugged in. Have noticed the red alarm light no longer comes on/flashes when I arm the alarm but the hazards flash three times still and the engine still starts okay so not sure what has caused that!?
Post #980497 30th Jan 2023 1:55pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
It could be that the connector isn’t pushed home properly. Try unplugging it and plugging it in again.
Post #981583 6th Feb 2023 10:58pm
TamarBlue11
It was a fuse. The same fuse does the clock, interior light and alarm light it appears!
Post #981630 7th Feb 2023 10:47am
